1 - 11 of 11 Posts
So I went to change my oil yesterday and discovered that the K&N filter is stuck on the bike. The bolt on the bottom is now stripped and the thing refuses to budge. I don't want to do the screwdriver thing untill I hear any other suggestions from you guys. If the screwdriver method is all I got then I'd like tips from anyone that has done it.
Thanks for any help.
Get a smaller socket and bash it over the rounded off nut.
i.e. if it's 15mm, try a 14mm socket, and use a 12 face socket, not a 6.
HAHA, I did the screw driver thing. I even crushed the oil filter using a strap wrench. I eventually had to use a screwdriver. After almost ripping the filter in two. It finally loosened. Make sure you lube the gasket really well when putting on the new filter. Have fun :)
Discussion Starter · #11 ·
Thanks for all of the advise. In the end it came down to the old school method of ramming screwdrivers in to it. I'm happy to announce it's off and I can ride again. What a pain in the ass! Anyone thathas this problem in the future don't be hesitant like I was to jamb a screwdriver through. Just keep it low and you'll be fine there is plenty of clearance below the threads.
1 - 11 of 11 Posts
