Hi gents,
I wish you are all fine.
I need your advice-opinion on the following issue.
Bike ST4s MY 05 with 5AM ECU.
I have two ECUs. The OEM W103 with the standard map and a W610 with a DP map.
Every now and then I would replace the whole unit and run the bike.
On the bike now the W610 with the DP map.
Last Sunday I wanted to take a ride and try the two maps on the motorway back to back.
I came home and tried to write the standard map on the W610, and test the bike instead of taking the fairing off and replace the unit.
I used the Guzzidiag, and to my surprise when the writing was finished I got the message "something went wrong, Try again later".
After a few attempts I got fed up and I wrote the DP map and everything was fine.
Searching in the forum, I bumped on to a note from Bradblack, saying that you cannot write a map from a W103 ECU to W610, without any further explanations.
Any idea how can I do it, if it can be done?
Thank you for your time and attention
Kind regards
Stelios
Just Visiting Your Planet
If Brad says it can't be done, then it probably can't be done. You can ask him.
Just curious though, what are the file sizes of the two maps? Are they the same?
Good morning to all.
Thank you for your answers.
N-Pro, I meant the Guzzidiag as a concept, of course it is the IAW5xWriter that I used.
Yorik, Yes the files are exactly the same size 320 K each.
belter, that means that I am stuck with the standard ECU and the standard map. Does any body have a standard map that I could write on the W610 ECU?
Thanks again
Stelios
