The shorties look like a sub $100 fix that will put the shifter further foward; giving room for you foot AND give you GP (reverse) shifting.
SSR website show a pix of the shifter location (near the front sprocket). The toe piece is eliptical; you can rotate it increase the distance (slightly). Above picture shows the shifter at full length, it can adjust to a shorter length, giving more distance to the footpegs. You can guesstimate if it will give you the length needed using the above pix.
Sport 1000 Biposto:
Paul Smith Fork Guard & Oil Cooler Guard, GTRossi Touring Hugger, Fat Duc O2, Fastbike Fork Frame Swingarm Sliders, Desmo Case Saver, Gerhart Gauge Lowering Bracket, Kuan Steering Damper, AG Hammer Fork Brace, Dobeck EJK, caCW Air Filters, TPO Idle Air & Crankcase Breather, Aella EVO.
This is for a gt1000. I looked at those shorties and while it gives gp shifting which I want it faces rearward? And decrease the distance from foot peg center to shift lever center? Am I looking at this wrong? Wouldn't be the first time
