21 - 32 of 32 Posts
If your concerned about heat and back pressure think about what the stock setup with the catalytic converter does.
The stock setup is probably as good or better than the aftermarket muffler with a big cork in it.
The key to the stock setup is... the emissions and programming are set up for it... and warrantied, if that's an issue.
Again, I'll be curious to see how the OP's modifications work out... there might be a workable solution yet.
You can purchse the endcaps with the groove for the dB killers and the dB killers from Arrows rep. Then you just drill the rivets and change the end caps. I did that on my CF Arrows and have no problems at all after five years of using the dB killers.
I got the parts from here:
Eric Gruell
Arrows Special Parts Distribution Center
SpeedMob - Richmond
1445B South 50th St
Richmond CA 94804-4605
United States
510-232-4040
975299
975300
haloguy628 nailed it, this is the best solution for OP to get what he wants without having to buy a whole new setup.
Geez... I never thought to see if they had a US distributor... I was thinking OP would have to get parts from Italy. Nice!
Eric Gruell
SpeedMob - Richmond
1445B South 50th St
United States
510-232-4040
This is amazing, I have the same problem the fella I purchased the bike from over drilled them and it's just too loud. What did you pay for the DB killers?
Discussion Starter #28
Eric Gruell
SpeedMob - Richmond
1445B South 50th St
United States
510-232-4040
View attachment 975299 View attachment 975300
Thank you. This is excellent news and I will look into it asap.
Michael
Eric Gruell
SpeedMob - Richmond
1445B South 50th St
United States
510-232-4040
This is no longer an option, they went out of business. Not sure if Arrow has a different distributor in the US.
When I needed to order a replacement emblem plate for my silencer, I used Motovation USA. They have an option on their site for a custom parts order. I gave them the part number from the Arrow spare parts guide as well as the info about my exhaust to confirm they were getting the right part. They got back to me with a price quote in a couple days.
21 - 32 of 32 Posts
