1 - 2 of 2 Posts
its under the gas tank, you have to remove all the gas tank plastics (LOT of 3mm allen bolts), then the bolts holding the gas tank down; one is under the bike (above the rear wheel) between the exhaust pipes and one is on the side of the tank. threaded into a pin that slides through a rubber grommet on the frame. You can lift the tank back and get to the battery, ECU, etc from there
1 - 2 of 2 Posts
