61 - 64 of 64 Posts
Also with the HW103 another (+ 0x0040) along is a (16x1) table where to me the 16 rows lines up with a temp legend, the other 16 row legend I know of is volts.
But that's me done with tests on the bike for a couple of weeks while I'm away.
While away I looked over some of my ride logs taken using the ScanM5X app. The ignition line in a chart never made sense to me as it didn't always tie-up with "Ignition Main". Now I have these other ignition tables it does.
On the screenshot I can follow the transition over 3 tables:
"Main"
"Idle-3,200 TPS Open"
"3,200+ TPS Closed"
I have a forth but not discovered it's influence yet.
977425
977427
A little hasty in naming the Ignition correction tables.
Back to testing in the garage. I wanted to see the transition more clearly between "Main" and the "Correction 1" table.
So I populated the whole of "Main" with "0" and the whole of "Correction 1" with "5".
Here's a screenshot of the logged result showing the switch more clearly.
Angelo - this is pretty much what you've seen at around tps 4.5. But my timing disc showed less advance but the same 4.5 tps switching point.
977430
Discussion Starter #64
Hi Steve,
How much less advance ?
Intrigued by the findings of a member in a Laverda forum, regarding the accuracy of the timing of a strobe light
- meaning the flash and the spark don't happen at the same time - I set up a bench test that showed that my strobe
was off by + - 3 deg. at some (rpm) points.
I have little confidence in the readings of my strobe after that.
61 - 64 of 64 Posts
