Ahhhh, good thinking. Also - ATDI? Nice song selection!I put a couple of hooks on the main support beam in my garage. Then I hooked the bike with some ratchet straps from the upper triple clamp. I used a rear stand though.
http://www.youtube.com/watch?v=oDvKpK-CM2M
Good luck with the clip ons - hope they work out for you!Is there a tricky way to go about doing this? I need to replace my bent ones from my spill but I'd rather not have to invest in a front stand at this juncture, for this one job...
Another brilliant suggestion, since I actually DON'T have any open beams and had resorted to thinking about maybe using a tree branch...Papa's idea also works from an A-frame ladder if you don't have open beams available.
I'm sure they will, thanks again for the awesome deal Kevin.Good luck with the clip ons - hope they work out for you!
+1 why do you need a front stand? you should be able to just pull off the top clamp and slip them off that way.no reason to use a front stand at all.
just remove the upper triple and then the clip ons.
Welllll...I don't have a rear-stand at the moment either and I was thinking it might screw up the alignment of the forks if I pull of the top clamp while the bike's on the side stand? Plus my other main concern was having to deal with some sort of headset adjustment if I pull the top clamp off...is that a legitimate concern?+1 why do you need a front stand? you should be able to just pull off the top clamp and slip them off that way.
I was thinking if I could get the front up, then I could just slide the forks down a few inches, pull off the bars, pop the new ones on, and slide back up...but definitely please let me know if there's a better way.
Cool, I might just use this method in combination with spyvito's idea of the jack stands (which I DO have) and rod...I have changed my clip ons 4 times. I've tried using different heights of clip ons, and never once have I used a rear or front stand. Loosen the 3 bolts holding the top triple clamp on, remove the 2 bolts holding the triple clamp to the gauges and the triple clap will come off with some help from a mallet. You won't have to worry about the forks not being aligned because the lower triple clamp will keep them where they should be.
"Fork Alignment" is really "Triple Clamp Alignment" - that is, the alignment of the top triple clamp with the bottom triple clamp. How does the lower clamp hold the alignment all by itself if the alignment we are speaking of is the alignment of the upper clamp with the lower clamp? This is especially difficult to understand while twisting force is being applied to the fork by the weight of the bike while it is resting on the sidestand.Loosen the 3 bolts holding the top triple clamp on, remove the 2 bolts holding the triple clamp to the gauges and the triple clap will come off with some help from a mallet. You won't have to worry about the forks not being aligned because the lower triple clamp will keep them where they should be.
While you are right, the geometry is really only stressed to the point of needing the triangulation of the upper clamp while under way. Take a look at he lower clamp and see if you think that, at rest, anything will be stressed enough to actually move. It won't."Fork Alignment" is really "Triple Clamp Alignment" - that is, the alignment of the top triple clamp with the bottom triple clamp. How does the lower clamp hold the alignment all by itself if the alignment we are speaking of is the alignment of the upper clamp with the lower clamp? This is especially difficult to understand while twisting force is being applied to the fork by the weight of the bike while it is resting on the sidestand.
I do not doubt your story: that you have done as you describe and your bike still functioned. That, however, does not answer my question.
I have also used the block of wood and 1 tiedown this method works great too.you can also reduce the twisting stress on the forks by putting a small block of wood under the side stand so that the bike is closer to level. don't make it dead level or it can tip over, but you can get it pretty close and do the job with a minimum of drama.
i've done it several times myself on three separate bikes (a gt and two s1k's) and never had a problem with alignment or tip-overs.
