1 - 9 of 9 Posts
For those who have already done this, how did you remove the locating tit on the handlebars, for the front brake & clutch lever clamps? :confused: Vice grips and pull them out? or tap them in with a punch? or another way? TIA Alex
You're gonna love my nuts...
Hi Alex!
I used a Dremel with a grinding bit and took the pins down. Worked great and only took a few minutes.
I think there are 2 different items here.
The brake housing has a pin cast into the clamp, that needs to be ground down.
The clutch side has a removable inserted pin, that pops out with a pair of pliers.
(At least that's what I think I remember when I re-did my bars.)
I think you're right Charlie. I think I tried to remove my brake side first, couldn't, so I grounded it and the clutch side down.
I do remember one of them kinda moved a tad when the grinder hit but by the time I realized, sucker was gone!
1 - 9 of 9 Posts
