1 - 3 of 3 Posts
Do I remove the rubber bearing seal on the brake side shown in the pic?
Also, what grease should I use on the spacers?
Thanks DUDES/DUDETTES
for the wheel spacers??? you don't need to remove the cover
just use some nice waterproof grease, and make sure your axle is clean and lubed.
Yeah, I thought it was weird too but the instructions from Fast Frank are:
"The next tallest spacer goes in the Right side of the wheel (remove stock spacer and seal, you won't need these) #2"
verbatim
1 - 3 of 3 Posts
