Seriously, 190/50's should be illegal on a sportsbike, if you are found with one you should immediately be banished to the Harley corner.
Ben, just wondering what you mean by asking if "
190/50 is the correct size"?
If you want something OEM to put in a glass case then there is no arguing with what you posted from the manual.
If you mean something else, ie "better handling", "better grip", "more agility" then that's a whole different question.....and the correct answer is "it all depends" Depends on what? What
you want from the bike, and what you mean by "better".
Something that a lot of folks have a misconception about is what a 190 does on a 5.5" rim, vs a 180. Many folks just pinch the bead of an unmounted tyre and think the pointier parabola that appears is how the tyre will be when mounted:
absolutely not so.
For this to happen the circumference of the tyre would have to change, but the
reinforcing in the carcass makes this impossible, all they have done is distort the bead, something which is corrected once the tyre is mounted.
So the tyre profile does not get more "pointy", but it does get
distorted, staying much the same in the middle but bulging more towards the edge of the tyre. Forgive my crap drawing, but something like this for say 180/60 vs 190/55 (approx same diameter) mounted on a 5.5" rim:
Supersport racers
love the 190 or even 200 on a 5.5" rim because they can get a big fat contact patch like this (albeit running just 26psi in a Pirelli
hot off the warmers):
That's Shakey Byrne (BSB) but you get the idea: any handling compromises are acceptable if you can get a contact patch like that, even with "only" 150hp in a SS machine.
Even if you're not Shakey slumming it on here, realistically it's not a night vs day handling difference, it's something you can largely make up for with the geometry adjustment available on a Ducati (I used 23.5deg steering head angle even on the road on my old 916).
You've just gotta ask yourself what does "better" mean for you? Is slower initial turn-in actually "worse"? Or just different? You might like slightly more agility if you're carving canyons, or maybe you want the big footprint for punching out of slow corners at a stop/start goat track. Or you might just want the extra mileage a flatter 190 centre section gives you if you're touring. "Better" is a very subjective thing.
