1 - 9 of 9 Posts
Dear mates
today i was thinking to ride my bike
after 1 month without use it but unfortunately she didn't start
i check the battery output but the screen show around 12v it should be enough?
there's no light or common error signs ,it flashes 2 times the red led alarm
after the check when the code sign disappear:confused:
i have check all the wiring founding the relay behind the battery with a bit of oxidation
so i WD40it but nothing as changed:( so what happen?
it could be still the battery KO? i think no....
HELP
batterys too low
thanks Kaos
but i have charged the battery and the bike won't start
it could be the regulator-rectifier?? i have seen the voltage go up to 15v
when under charge then drop down to 13v:eek:
it seems weird and that should be related to regulator issues??
Battery too weak.
There should be somewhere around 13.4 without charger on it. 12v is too low.
Get a new battery, give it a slow 2amp charge for min. 12 hours, then plug n play...
A fully charged battery that has settled after charging (a couple of hours) should show 12.8v pretty consistently over days and days, perhaps even weeks. Less than 12.4v indicates a weak battery. 12v is pretty much dead as far as starting your bike is concerned.
Discussion Starter · #7 ·
thanks to everyone
i solved this issue cleaning the relays behind the battery and charging the battery for longer time
like you suggest me;) all the night, now start at first hit
The 999R I'm riding at the moment has a similar issue. Once it finally starts, it's showing 13.6v, but if I shut it off and restart it later, it's showing 11.2v.
New battery too..?
Make sure you are reading your running voltage at 3000 RPM or more....
1 - 9 of 9 Posts
