1 - 2 of 2 Posts
I think mine must have been changed as the eye that bolts to the frame at the side does not have an offset for swinging 180 degrees when you change the steering head angle.
I can't find any part numbers and if I change the head angle to 23.5 will the damper still fit in that position?? Come to think of it, it would be off now the way it is:think:
Can you just change the eye on the end for another part number from ohlins??
Discussion Starter #2
And also does anyone know the length of the spacer that sits between the damper rod end eye and the mounting pint on the frame as mine is missing.
Thanks again
Nick
1 - 2 of 2 Posts
