Hey Manny when you install the ECU, I would remove the battery ground cable first. Then remove the ground cable that attaches to the ECU. The two harness clips to the ECU, you remove them by rotating them half a turn. Don't forget the ECU ground cable when you install your race ecu.
And yes, you should have your tps reset.
