I recently started a thread asking some prelim valve questions. The answers were very helpful. I spent a fun evening taking everything apart, getting ready for tomorrow.
For anyone getting ready for their own winter work, here's a quick summary of what i did:
1. drain oil
2. drain coolant
3. remove gas tank/seat/rear fairing (migz123's thread was helpful. tip: removal of fuel delivery/return fittings was easy with a flat screwdriver prying off the plastic ring; be sure to put some rags down so catch the few cc's of gas that spill. i left some in the tank, as others recommend doing, to verify o-ring competence after changing out the fuel filter. just flip the tank to keep it from spilling.
4. remove oil breather box, horn
5. remove cooler/fan after removing the air scoops (PITA to pull the cooler from the manifold hoses. beware: pulling off the cooler from the manifold connection hoses results in big spillage of coolant; i bet someone else has discovered this before me!)
6. remove belt covers
7. remove valve covers
here's my questions:
1. any easy way to remove the fuel lines without removing the breather box?
i did like LT said and just pulled them out of the way. i don't like putting too much stress on them and am worried about access with my torque wrench when the job is done.
2. this is TDC for the cam on the left, correct?
3. To correctly maintain the timing, when i replace the belts i need to make certain the two cams are aligned as they are in the picture above?
thanks in advance, boys. i appreciate all the help i've been getting.
to anyone on the fence about doing their own valves, i suggest you DO IT! (Of course, my failure is waiting to happen and i may be singing quite a different tune soon...) taking off the valve covers and finally seeing the desmo valve train was just cool.
1. drain oil
2. drain coolant
