1 - 2 of 2 Posts
looking to remove the thermostat on an early 999 (with the early cast water pipes) for track use. Fans are removed too.
I have read on here that the lower hole was blanked off, as shown in the picture.
Does this need to be done, or can it be left as is?
Cheers.
Hi,I don't possess any mechanical/technical ability, but.... my tech removed my 2006-999 thermostat several months ago. If what I'm looking at in your picture is the thermostat housing, mine is not aluminium, he blanked off the hole.
Hope this helps.
1 - 2 of 2 Posts
