1 - 11 of 11 Posts
I've been running my 999R with a direct reverse shifter, but do not really like the additional throw or the fact that the lever moves in an arc away from your foot while shifting. I am going to switch back to the linkage setup, but need a shift arm that will clear everything when mounted 180 degrees opposite the stock position. I've read that newer Monster shift arms work well, but can anyone tell me which year/model monster shift arm I need to be shopping for? Any help would be appreciated.
Discussion Starter #2
Did a bit more digging and came up with the answer here. Looks like the part number for the shift arm is 456.1.046.1B, which can be found on numerous Ducati models.
Discussion Starter #5 (Edited)
Did this work? Looking to do the same thing for my '05 749S...
Yes, worked like a charm. The 456.1.046.1B part number is from various Monster models that has a different angle compared to the stock piece that allows it to clear everything when running a reverse shift pattern.
Many thanks for the quick replies, esp. on a year-plus old thread! One quick follow-up rabbit45 - do you have an aftermarket clutch slave cylinder? Just wondering if the different angle of the Monster part removes any potential for interference with a larger slave...
I use a direct lever and find that preferable but if you want to flip the existing linkage then you need (at least on a 916 series bike) the arm from a Monster (or similar) - the critical thing is that you need the straight arm not the offset arm from the SBK as it fouls the casing when fitted upside down.
This type;
Discussion Starter #9
Also, for anyone who might be interested - came across this part from Podium Racing in my research:
NEW DUCATI GEAR SHIFT ARM STANDARD AND RACE STYLE REVERSE SHIFT 749 999 R & S | eBay
My fear with this part is again with clearance around a larger aftermarket clutch slave; anybody have first-hand experience with this piece?
I have an STM slave on the bike and the Monster shift arm/heim joint combo clears the slave without any issues. I had seen the shift arm you posted, but I believe the Ducati part was about half of the price...
Why is it that people own a premium bike but are stingy when it comes to buying bits for them. Spend a FEW bucks more and get a REAL shift lever, far more positive feel.
I didn't need to buy anything. Just turned the original arm around. No clearance problems but had to take heat gun and make a small depression in the sprocket cover. Been riding like this since I first got the bike in 2004
1 - 11 of 11 Posts
