Hi Folks,
Long time Japanese bike owner, and most recently converted to the wonderful world of Ducati (and never plan to return to the 'dark' side again!)
This past weekend, I installed HID's on the 999, as well as did the mod to my switchbox whereby the running light stays on when the hi beam turns on.
Now, I am having all sorts of funky issues.
Sometimes, when I turn the bike on, the running light chooses not to turn on at all. I know this isn't an HID issue or a ballast issue, they have both tested fine.
As well, when I switch from my running light to hi beam, my running light 'sometimes' turns off, and simply won't turn back on at all!
One thing that is strange that I have noticed (that may help diagnose this problem). When I turn the key on my bike, the headlight comes on like it should. When I actually 'start' the bike, it has always turned off for a few seconds, and then turned back on. This was regardless of halogen or HID's. Is this normal or could I have an electrical bug?
Any ideas are greatly appreciated. It could be I have a defunct switch, or perhaps need to go back and recheck my soldering. I am 100% positive the HID's themselves are not the issue.
On a side note, I am having a tough time finding the 03-04 service Manual (mine is an 04). I have found the 749 service manual though, since they are relatively the same bike will the specs be the same? In particular, engine specs (belt tolerances/valve specs etc)
Cheers!
Cheers!
