I figured I'd try this too as everyone seems to be at it nowadays, but with a twist.
Forget the perforated straight pipes... how about "expansion" chambers that connect like an H. Could you imagine the sound?
Starting with a regular old grinder, I plan to split the two halves of the stock exhaust shell. Leaving the entrance, and exits pipes at the stock widths (54mm)... I want to change the inner diameter of the pipes to as large as I can. Cut out the circling, perforated, glasspacked mess that Ducati put in there to restrict it and make it quiet
I also want to connect the new two pipes with an H connector. Should allow for a small bit of back pressure and even a lovely burble on the downshift.
Let us see what the metal working and welding company say tomorrow!
Any notes from those in the know are appreciated
