Hey guys, just wondering if I can use agip permanent spezial to top off my 999 since I have a ton of it, if not, what do you guys use or raccomend?
The shell advance looks like it's no longer available.
Thanks
Come in Spinner :)
The short answer is no.
Never mix different coolants in your system as seven times out of ten they will react with each other and turn acidic.
Just drain and flush the system and refill it with a 100% charge of the agip you have.
Thanks bud, I had that feeling.
Cheers!
++ on lean the bike over if draining and refilling as they are prone to developing Airpockets. I strap my bike up and use a wratchet strap to get a good safe lean over.
