Known to happen...
Right - gut the filter contents & stick your head under the bottom of the oil filter/use a mirror to look up inside it? You SHOULD have a series of six holes in the very bottom of the filter?
Using a pair of GOOD long-nosed pliers open them up and stick the prongs in two opposite holes.
Stick a ring-ended long spanner/wrench on one handle and use the shaft to push the other plier handle round....
http://ducatiforum.co.uk/f41/oil-filter-horror-3826/
Here's hoping this gets your filter out... I had grief with my first filter? Have since swapped to the K&N KN153 filters, these have a 19mm hut on the end to spin them off?
KN-153 K&N SPORTS OIL FILTER DUCATI 916 Biposto 97-98 | eBay
Will pretty much fit all the dry-clutch motors +?
