1 - 14 of 14 Posts
Hi All,
I keep reading that certain 999 models have 20mm of adjustable seating.
How exactly does that work? Does the whole tank assembly move back and forth? Can you adapt that to any of the 749/999 bikes?
Discussion Starter · #6 ·
Thanks Guys!
Hmph. I have an 05 Dark.. which does not adjust. Darnit! Because I'm pretty short, and a little extra reach would have been really nice. Oh well.
rustysrustyduc said:
Thanks Guys!
There are 3 positions to adjust the seat, the difference between the forward-most and the rear-most settings are 'about' an inch and a half apart. Your Dark is set to right 'about' the middle. Even if your seat was adjustable and you adjusted it forward, you would barely feel it, so don't worry about it too much, coz you're not missing out on a whole lot ;)
If you really want a better reach, then you are best-off upgrading your clip-ons to some FBF or Helibars for 'about' $250... then you're likely to feel some meaningful difference.
Discussion Starter · #9 ·
Herbivator said:
Loosen the 2 hex head bolts that bolt through the bottom sides of the seat into the bracket on the subframe. Everything moves as one.
Wait, so are you saying the tank/seat/rear cowl is ALL held down with only *two* bolts?!
I had the chance to take a look at the bolts under the seat, and I could see the different position, but now I'm a bit perplexed as to where else needs to be "adjusted" to get the assembly to move forward.
Yeah, I think a set of bars would be good too. But it would be nice if I wanted to turn my biposto into a mono, it would mean I could get the adjustability as well.
Can anyone provide additional details how this is done? I've got both of my hex bolts out but it doesn't seem to "slide". I assume only the Tank and seat slide forward?
Yes, only the two bolts through the seat grab handle on each side, plus the two that go straight up into the tail cowl on each side. Have to remove all four to adjust the seat. Total movement is 20mm or +-10mm from the center hole. Once all the bolts are out, you can lift up on the seat a bit and see all three holes right behind the grab handle where you took out that bolt. It does not slide foward are backwards easy. I had to take a center punch and stick it in the hole and "help" it out a little. The entire tank/seat/rear tail section all move as one unit. Hows that?
cheers galaxy
You're the man brotha, thanks!
1 - 14 of 14 Posts
