1 - 20 of 21 Posts
Have decided to do only track days for now. So sad to say my 998S has to go. It a customized 998 so its better to part out than sell as a whole bike. It is a European 998s motor so it came with 996r cams(1C intake and exhaust) these are the same cams as the 999s as well. Has a fresh 1198 forks and radial calipers with ebc hh sintered pads. Has a 749R triple clamp 30mm or 36mm adjustable offset. Koso digital gauges. Evr 48 tooth clutch assembly. Custom fabicated 1098 exhaust to fit the 998 motor and frame. 848 swing arm coversion. Clean titled gold powder coated frame and headlight bucket. 996s aluminum subframe. Ohlins steeribg damper and rear 848/1098 shock. Carbon front fender & heat sheild. Tank is in excellent condition. Monoposto rear cowl. Aftermarket rearsets. 848 rims with new Dunlop gpa tires. Afam quick change rear sprocket. Carbon fiber airbox. Custom corbin seat with a gel pad in it. RSC19 front master cylinder with steel braided lines. Custom headlights with led bulbs. Much more will list later.
Carbon airbox $200
1C cams (996R/999s) $1000
1198 forks like new $600
Radial calipers with ebc pads $400
749R adjustable triple clamp numbered. $600
Koso gauges with oil pressure gauge and custom bracket $200
Evr 48t cluctch assembly complete $500
Custom fabricated 1098 exhaust 52mm carbon cans to fit a 998 with 848 swing arm swap $700
848 swing arm conversion with custom made rocker and ride height adjuster complete setup $1200
Gold powder coated 998 frame with clean title $800
Matching gold headlight bucket $200
Aluminum sub frame $250
Ohlins steering damper $300
Ohlins rear shock 848 $300
Carbon fender $120
Heat shield $40
Tank excellent condition $400
Fuel pump assembly $250
Mono tail fairing $ 200
Upper fairing $300
Mid fairing $175 each
Rear sets $150
848 rims with new gpa tires $800
Afam quick change sprocket $175
Corbin seat $225
Rsc19 front master cylinder $300
Custom fitted led headlight assembly $500
More is available if not listed. Prices do not include shipping. Text or call for more info. 407 617 7496
How much would you take for the seat? Also, does the seat cowl have the screens in it? Did not look like it did, but I thought I would ask.
I might be interested in the engine wiring harness, as long as it is a original 998/testa version. Thanks
PS: also might be interested in the CF airbox. Who is the manufacturer?
Seat cowl does have the screens
Discussion Starter #7
Dont know the manufacturer of the airbox. But it fits well
Discussion Starter #10
Also has a stock flywheel that i shaved off the excess weight for a lighter one. Also have an aluminum fly wheel. $100 each
WSB 1.84 light primary gear will fit 996 998 maybe even 999 $250
Discussion Starter #11
Also have a 996R ecu $500
Stock 998 ecu $150
Discussion Starter #13
Also have warrior (bursig copy) side lift. Was originally designed for the 848 and newer but i adapted it to fit the 916 style bikes
$350
Discussion Starter #14
T-rex reveseable rear stand
$150
Messaged you, but your mailbox must be full. If oyu xan send ne pics of the sending unit, I would appreciate it. Thanks! I am interested.
Discussion Starter #16
Subframe sold
Mono tail sold
Fend e r sold
Airbox sold
Damper sold
Triple clamp sold
Discussion Starter #17
Is a Warrior made copy of the bursig stand made for 848/1098 bikes. I machined a new block attachment made to fit the 748-998 bikes as they didnt make it for them. Put a wedge in it as well to keep the bike from tilting on the stand. Works well and i have the original plate as well.
Discussion Starter #18
Have the post to fit the 10mm bolts on the frame as well for earlier bikes
Discussion Starter #19
Ohlins damper new $350
749R 30-36 adjustable triple clamps
Rare $700
1 - 20 of 21 Posts
