I´d go with the 711-502 map and replace your DP ecu with stock ECU and run it from there. Having both a PC and a DP ECU isn´t really necessary, since they essentially do the same thing (until you get it dyno´d).
Once you get it on a dyno, try both ECU´s with stock setting on the PC to find out which is better.
If your in Australia, I´d give Brad Black over at Moto-One a call. This guy definatly knows a thing or two about tuning Ducati´s. (03) 9568 0100
http://www.moto-one.com.au/performance/index.html
