So my 998 has more oil pressure issues. I replaced the pump and no oil comes out of the feed line to the cooler or the line going to the heads. I’ve been testing with the plugs out by the way.
Before buying yet another pump, I am considering other culprits. In an older thread, Davey j mentioned the oil bypass spring. So I had a look and it looks as if it’s…peeling? What is going on here?
The other potential culprit I guess is the ring on the clutch cover which is also slightly torn.
I’ve checked the o rings and even replaced two that were missing.
Any help would be greatly appreciated. I have two many red herrings.
I’m beginning to think I’ll never ride it again.
