the problem has occurred intermittently since new, Ducati extended the warrantee to 4 years but the dealer was never able to find the problem. (I will credit them for fixing other electrical problems).
Problem: (only when engine is warm). ignition is turned off then on. fuel pump primes & engine turns over with no apparent spark. turn the ignition off then on and the bike will start immediately every time.
have swapped ecus with same result. the ignition switch is next. if that doesn't work I'l try swapping out the kill switch.
anyone had this problem? any suggestions?
