The bike was not running for some time. And since I got it running almost 4 weeks ago, the clutch fluid quickly got dark. It is possible that moisture found its way into the system and caused the
clutch fluid to degrade.
I attached a vacuum pump to the slave cyliner, pumped vacuum pump to build pressure. Then pump the clutch lever a couple of times, then closed the valve before all the pressure from the vacuum pump is down all the way. I did this a few times until the fluid was clear.
After bleeding the clutch, the neutral light stays on through all gears.
Searching this forum suggests that the neutral switch may be grounded or going bad. Where is the neutral switch located? I had a bit of a spill when filling the reservoir. Would it be possible that a short in the controls under the reservoir is causing the neutral switch to stay on?
Did I bleed it wrong? Do I pull the clutch lever, close the valve then let go of the clutch lever?
