My 998 is getting 25 mpg or less and idle poorly. Tbs need to be synchronized. Checked the tps, which checked out ok. Has 996R cams,996R ecu,52mm exhaust from 1098, aluminum flywheel. Cams and valves are adjusted to correct specs. Runs ok at higher speeds. Unknown about the rest of the motor as i just got it.
Just a thought here but it sounds like a lot of non standard components are fitted to that motor. Unless it's been mapped correctly for that configuration it's gonna run like a bag of kats.
melillimoto adjusted co trimmer and did a basic tune on the motor. co trimmer was set 37, way off, reset to 10. runs great now.
