On the 5.9 ecu, idle is effected by the bypass valve settings, whole range by the trimmer.
You will see that changing the trimmer, the idle changes, to be corrected with the bypass valves.
Thanks gentleman. That is what I had thought but a well respected Ducati Dealer/Mechanic told me the trim only adjusts at idle, as he was suggesting a Microtech ECU.
