Trying to figure out why my fans are suddenly stuck on after service. I did a major annual, belts, valves, hor. head gasket, motolectric wire kit and FH020A R/R.
Before all this, my fans would turn on for 2 seconds on ignition on and then click off. Now they just stay on. I can't figure out where the fan relais are on this bike - there would have to be 2 of them as the fans can turn on individually, no? Or is this handled directly by the ECU (as the diagram implies) without any relais, in which case there must be something going on with my coolant temp sensor?
