1 - 7 of 7 Posts
998 (916 Series) Cush Drive Nut Thread Size?
Can someone give me the thread size for the 998's (916 Series) cush drive's 5 nuts?
TIA
Super Moderator
What he said!
- and the the Allen on the other side is 12mm as i recall..
side note, the back side of the cush bolt is a 12mm, however, i was able to use a 3/8s drive inserted in it to hold it in place. I dont recommend this if you need to apply more torque than specified to the nut (because it is seized/corroded)
Super Moderator
+1
Did that myself when i was lacking the right tool. :)
//amullo
1 - 7 of 7 Posts
