There's are really simple adjustment on the 916 998 in the linkage.
Simply tighten or loosen the linkage. Done.
alexxx
alexxx
I guess I am not alone.... thanks.My 998 has always had a petty clunky gear shift, and first to second can be like slamming a van door.
Could you explain please. Thanksborrow a GP shift....
How does your 998 shift from 1-2?install a reverse shift pattern pedal and you will be able to determine if the issue has do with your standard shift linkage or if it is something more insidious
No problem... I know the newb thing can be annoying and rightly so does require ribbing...my apology.....really....didn't mean to come off harsh....just a little ribbing that can lose flavor if not in person i guess -
