I know the figures arent really comparable but you might be interested in this. Think the cam timing is as mentioned by Tom Tom
Tom Tom, Chris did explain the timing but it went over my head (whats newYour welcome!
Ducv2, the cam timing is different on yours, if the first peak is lower than the second your more towards 115 intake, 111 will even them out and 109 will make the first one slightly higher, but still keep the second good enough
Im good friend with chris.
Yes. While you're at it, you may want to do the upgraded piston kit for the steering damper.Stripped 996SPS with yours truly...thanks again for the inputs!
Quick question
I will have the front forks serviced (seals and oil) would it be necessary for the Dampers & Rear shocks as well?
You're welcome and congrats. I like the wheels. Pick up a black seat (easy) and a nice stock upper and you'll be good to go!Thanks Adam will check it out & request this then.
Prophet, The pirelli supercorsa sp are nice aren't they I have them on my 999R as well.
