1 - 12 of 12 Posts
Counter shaft seal would be the obvious guess? Take off the sprocket cover and maybe also the sprocket, clean all the chain gunk off everything. Run it for a bit and you'll see where it comes from
Take the cover off and check for signs of a chain derailment. My 996 would be fine until it warmed up, then out of the blue it would leak oil.
Drove me crazy trying to find it. One day, after a ride I left it running in my rear stand. When I did I looked all around the area and it looked like what you describe. Only when I pulled the clutch slave and the cover I couldn’t find a leak.
I finally started it back up and let it run without reinstalling anything. I found them that the alternator cover was cracked, and seemingly leaked out of the cover itself.
Not at any point near the cover/crank case join either. Oil just came out of the cover in the area normally occupied by the clutch slave where the cover curves around it.
Once I cleaned up all the old chain lube, I found the chain had derailed at some point in the life of the bike. The gouges left behind are unmistakeable.
When I removed the cover I found it cracked from the inside as well as deformed from the force of the chain striking it.
I replaced the cover and installed a case saver from MotoWheels. Luckily for me, the damage to the crank case half was negligible and a little work with a mill file dressed up the minor deformation of the mating surface.
I was not so lucky on my Supersport engine. It got a new engine and a case saver too.
often they leak oil out the clutch pushrod when the sealant between the alt cover and cases fails. most common leak i see.
Thank you
Discussion Starter · #6 ·
Thanks for sharing. I'm printing all the suggestions.
Let's make a bet on the source of leak. Someone willing? Here's $10 to it being the clutch push rod o-rings.
I’ll take that bet ,, mine leaks from around there somewhere too ,, Not the pushrod o-rings
985211
1 - 12 of 12 Posts
