my bike getting poor mileage. also smells bad behind me , on petrol. fuel.
cons. is about 9-10 liters /100km
it have unknown eprom.
is possible to put fuel a bit down somehow?
not on idle, but at load/driving.
check fuel pressure
check compression / leakdown
check tps set up and operation (on a diagnostic tool)
check other inputs on a diagnostic tool
check throttle set up
check idle mixture
should find it in there somewhere.
@belter: that bolt for adjusting mixure is just for idle? or also for driving conditions
I suspect on unadjusted tps. I will learn how to do it.. checking resistance on some ecu pins
will also check other things you mentioned
