On my 998 I run 3mm of deflection between the cam pulleys. I believe on the pre-Stretta heads you would run 4mm. As they are farther apart. I have also heard of some people using a 5mm allen key between the idler pulley. Meaning that if you can slide a 5mm allen between the belt and pulley you have the right amount of play. If you do a search on here you should find out more. You need to have the piston of the belt you are adjusting at TDC. The tension of the closer springs will throw off your readings otherwise. Hope this helps, Ken
