Super Moderator
There is a drainplug just aft of the pump.
Lift the tank and disconnect the fuellines (they are No-spill self-closing) and then unscrew the hex just aft of the pump..
Easy..
Siphon off most of it with a siphon first. That should get it down to hardly anything. I'm not messing with the drain plug on mine since it's painted over from the factory. I think I'll dump it out the pump hole once I remove it for filter replacement. Should be fun. :)
