why is this happening???
Adjusted the valves, put on new belts.... Buttoned everything up like normal.
Hit the starter button, it turns over twice and lights right off...sounds perfectly normal.
I adjusted the CO levels to make sure they were still at 5%. Everything is wonderful. Beautiful idle, revs up. All is good.
Go out today and hit the starter button and it turns over about 1-1/2 times and stops....same thing the second time. Sounds like it is trying to start a motor with 18:1 compression. Battery has 13.5 volts. What the heck??????
The day before if you breathed on the starter button it would light right off....... Any thoughts. I hate this stupid stuff. It's like I put fresh air in the tires and now it won't start.... Thanks.
