Hi, I installed these Soeedymoto adjustable clip ons with 20mm rise for 53mm upper forks.
Nice quality but main problem is cannot get full lock therefore can’t lock steering.
I have dropped the clamps 3/4” below the triple tree and still, the throttle housing assembly is hitting the inside of the windscreen (see pics) Just barely clearing the front reservoir cap.
I have tried various adjustments with the angle but can’t seem to get it right. I didn’t think Lowering the clamp so far down the forks would be necessary considering they are risers. Any suggestions would be appreciated.
Thanks
-John
Thanks, that’s a good idea I will look into those. Thankfully the reservoirs are just clearing my main issue is the throttle assembly where cable comes out is hitting when I turn the bars and can’t lock steering for anti theft safety. Plus my hand gets pinched between bars and fairing when making slow moving turns, bit of a safety hazard.
