1 - 3 of 3 Posts
Is it necessary to remove the rear shck and linkage to access the valve shims? I can't seem to get enough room to depress the closing rocker so I can check the unloaded gap. Is a special tool required ?
Not much room but it is doable. What are you using as a tool? I always used an 8mm 1/4 drive socket on the end of a long extension and it was fine. You just need to remove the crankcase breather box.
1 - 3 of 3 Posts
