Hello all, Just picked up a 996 with 5800 miles on it- there was about 1/4" of dust on it when I pulled it out, so i'm going through and doing belts and all needed rubber pieces, exc. I'm puzzled on the brakes however, I'll bleed the front brake and it will be very strong with good application, and then over 3 days or so it will get to the point where I can almost pull it back to the grip.
I'm thinking I have a leak somewhere, but all connections are dry, it's not coming out of the Master and both calipers are good. However, looking at the fluid reservoir I have air bubbles rising whenever I pull the lever, every time. Is the seal going into the top of the master known to go bad? any other places to check? I don't want to be blindly replacing parts.
Thanks!
Thanks!
