The Front brakes have been making a slight rubbing sound lately and I finally had a chance to have a look. The outside pad on the left Calliper is in there pretty tight and is wedged up against the disc, but comes out no problem. But Pads are looking fine and are well within tolerances. The other pad is loser, but still sits in there ok.
However, on the right Calliper the Inside pad is really jammed in there. Had to really work to get it out as it was pushed right up against the disc... hence the rubbing sound when ridding.
Question: How to fix this? Im thinking a good bleeding might be in order. Did a quick purge of the main reservoir to see if there were any air bubbles on the Master Cylinder side, and no bubbles. HAve yet to do a complete bleed.
Anyone have this issue before?
THanks,
J
THanks,
J
