1 - 8 of 8 Posts
Ok, this top ring/nut/yoke/what ever you call it has caused quite a chuckle when we went to get it loose. I see they make a $40 tool, however, what kind of ingenuity have ya'll used to get the damn thing loose? Pics are VERY welcome....Begin:
Two drill bits that fit real tight in the holes, spaced 180 degrees apart steel bar, wrench between them and turn.
Good ideas! I had the thought of two metal pins through through some kind of aluminum chunk i could get a wrench on. The pliers are a good idea...my you can drill your hardened tool steel? I guess I could get a cheap pair...
1 - 8 of 8 Posts
