1 - 6 of 6 Posts
Hi All,
I need some assistance diagnosing an oil leak on my 748. Bike is leaking oil from the clutch cover. I recently rebuilt the clutch slave and replaced push rod o-rings. I am not seeing any signs of oil on the slave side, but clearly something is amiss on the clutch side. I pulled the pressure plate and there is obvious oil pooling inside the center nut where the push rod protrudes. I pulled the basket and no signs of oil behind it, so I am stumped. Is there another push rod seal on the clutch side or can someone please point me in the right direction?
Thanks,
Brian
Thanks Guys! I searched a bunch of posts and I think it's the seal that I circled in the image. I just picked one up from the dealer, so I will confirm this afternoon.
PN: 93783.0812 Seal Ring
Discussion Starter · #6 ·
TNR: That was the culprit for me! Was an easy swap and new seal was around $6. I used a 6mm (or 7mm) socket to make sure the seal was seated in the shaft end and after a nice ride, had no signs of oil leaking.
Regards,
Brian
1 - 6 of 6 Posts
