There's a lot of good reading in the Halls Of Wisdom...
Basically, above idle and/or when cruising, the voltage should stay close to 14.5VDC (with a known-good battery). Here, in the USA, our lights are on all the time, so we're always feeding close to 5A into one of those elements. So I read a lower voltage here at idle...around 12V.
Bobsst298: Don't know about any "mod kit" other than the Ducati Campaign that placed an updated spacer/washer on the crankshaft, which dispences more oil to the stator windings, which aids in cooling of the stator. While they're in there, Ducati also replaced the stator, assuming the the original one might have been over-stressed.
To troubleshoot the stator, you should have low Ohms (around 0.5) between the 2 yellow wires. Do it with the wires unplugged (behind the radiator). Also check integrity of this plug. Next look for infinite (very high) resistance from either yellow wire to engine ground. If all this checks OK, I would CAREFULLY place a voltmeter into the yellow stator connector, making sure the leads don't touch, and don't touch gnd. Start engine.
Around 2000rpm, you should see 30 or 40VAC. As you rev engine to 4000rpm, this reading should double. Be careful of ELECTRIC SHOCK, because at high rpm, this can and will go over 100VAC. turn off engine.
If all this checks, plug in the RR again, and re-check battery voltage at idle, and then at 2000 or 2500rpm. At 2500, the reading should approach 14.5VDC (as the batt. charges).
