Hi Guys
I am selling my 98 916 with 15700 miles on it. It is in excellent condition. Has been recently serviced at Boulder Motorsports with Valve adjustments, new timing belt, oil change, radiator fluid (Water wetter). Has the following modifications to it. Always garage kept and battery tender hooked
Arrow Carbon full exhaust with ECU
(OEM ECU & Exhaust still available)
Ohlins rear shock
Pro-Italia Top clamp (Bar riser)
Carbon fiber Front & rear fender
Steel braided lines for front and rear brakes
Low temprature thermostat 190 degree - Evoluizone
Nicolas ligher flywheel + spare OEM Fly wheel
MBP Ducati rocker treatment for flacking
frame sliders
Evoluzione rear flasher integrator
Renthal quick change sprocket kit
License plate fender eliminator
BT002RS tires with 100 miles
Ducati vented clucth cover
Evoluzione larger clutch slave cylinder
fully adjustable Brembo brake and clutch levers
High performance airfilter
Zero Gravity Double bubble Dark screen
DP Touring wind screen
Extra Front body work
Extra Rear biposto seat bodywork
DID ERV2 520 Chain
Carbon fiber tank pad
Maintenance free battery
Special Ferrari emblem in the tank
Front pit bull stand and rear stand included.
Ducati workshop manual
U can call me at 7202446374
