I lost all gears above 1st. The shifter pedal feels light/limp with little/no resistance. Clicking down to 1st and it will drive in 1st gear, but the drivetrain is clearly not connected in any other positions. Clutch handle seems to feel and operate normally.
For the last 4k miles the bike would occasionally (very rarely) go into 'N' with a loose rattling sound (a couple of bits of metal rattling around somewhere) when shifting to 4th or 5th. Ok thats a bit misleading because I would have been between higher gears and not actually in true neutral. Today before the breakage that started happening a lot.
I'm lucky it happened close to home and not on the highway 30 seconds prior.
Does that description ring any bells for anyone? The
