1 - 2 of 2 Posts
1997 900 SS/SP. We had the cylinders taken out to 944. In the process the freeze plugs were removed. We purchased what was listed for the motor from Ducati. The plugs that were sent for the smaller openings are 16mm. These literally fall into the bore in the cylinders. Anyone know the correct size for the motor? Source? The larger freeze plugs are around 18mm (forgot the exact measurement) and do seem to be a good fit. We are concerned they may be a bit small. Anyone know the correct size for these? Source?
Thanks much, Stephen
1 - 2 of 2 Posts
