Fuel tank vent line maybe? I've seen a plugged or kinked vent line cause the symptoms you describe. Once the vacuum that formed above the fuel as the level dropped dissipates, things will be normal until the vacuum is greater than the pump suction....if your pump is still working/fuel filter or pick up sock not plugged up.
An intermittent electrical issue is a possibility too....but then I don't think it would matter whether you were at idle or not, it would just randomly quit. All I got....sean
