You failed to mention how many miles are on the clutch.
The standard test for detecting worn-out clutch plate friction material is to watch for slippage when accelerating in top gear. Some people are just harder on clutches than others, so service mileage will vary over a wide range.
You can often stop slippage by maintaining the force pushing the plates together. The idea here is to maintain the 38 mm new stack height as the friction material wears off and reduces the thickness of each plate. The higher the stack height, the more the springs are shortened/compressed, and the greater the force pushing the plates together. The clutch slips when there's not enough force supplied by the springs or the friction material is worn completely off.
The service limit on 3 mm friction plates is 2.8 mm. For 2.5 mm plates the service limit is 2.3 mm.
The plain metal plates come in stock 2.5 mm or 3 mm thicknesses. When the overall plate stack height wears 0.5 mm, replace one 2.5 mm flat plate with a 3 mm one. At 1 mm stack height wear, repeat for a second flat plate. At 1.4 mm - 1.6 mm wear, replace all the friction plates. Allowable friction plate wear is 0.2 mm (each).
Ducati considers both the plates and clutch basket to be wear items. By the time you need to replace the worn-out clutch plates the basket has been notched from the impact loads of the plates. Ducati specifies the allowable gap between the plates and basket as a quite small 0.6 mm, effectively saying to replace the basket and plates together.
Also check the pressure plate throwout bearing and pushrod for smooth rotation.
