1 - 3 of 3 Posts
When we measure the distance between the bolts that hold down the brake calipers, are we measuring the length between the *center* of the holes, or something else?
My friend has a set of Showa non-adjustables also from a 95' M900; will I run into any issues when replacing the current Marzocchi's?
Cheers.
Yes, center of the bolt to center of bolt. Should be 40mm on the '95.
1 - 3 of 3 Posts
